What is the best File shredder overwrite pass software?
Hello experts,
I would like to ask if what is the best file shreddeer overwrite pass software that can be used now that can also delete the old files.
Thank you very much.
Hello experts,
A lot of file shredders are available for download online, but one of the most easy to use can be found at:
This file shredding tool can prevent recovery of deleted files by overwriting the whole file with random series of binary data . The only downside of this software is that the developer doesn't have any kind of support for users so you should use it at your own risk.
Hello Tracy,
I recommend you check this file shredder software
It's a freeware and can work effectively with most PCs. I am afraid it might not work on Linux but its very good on Windows OS.
I hope it will help you.
If you’re looking for a good file shredder to delete and wipe free space in your hard drive, don’t look far. Go to CCleaner Free Download then download and install CCleaner Free. File shredding is included in its basic functions. Wipe free space is enabled by default on drive C but file shredding is disabled. To enable file shredding, launch CCleaner then go to “Options”.
In “Settings”, select “Secure file deletion (Slower)” in “Secure Deletion” then select how you want it done or how many passes you want. You can select between “Simple Overwrite (1 pass)”, “Advanced Overwrite (3 passes)”, “Complex Overwrite (7 passes)”, and “Very Complex Overwrite (35 passes)”. You can also enable “Wipe Alternate Data Streams” and or “Wipe Cluster Tips”.
To wipe the free space, select the drive or drives in “Wipe Free Space drives” where you want free space to be wiped. Remember: when you file shred and wipe free space, no files and folders can be recovered when you run a file recovery software.
