Hey guys,
I am looking for the best flash banner tool for making web  banners. I would prefer it to be free but I am willing to pay as long as it isn't too expensive. I am fine with it being complicated. While I am not an expert I am happy to spend the time to learn.
Thanks in advance.
What is the best flash banner tool for making banners?
Hello Sue,
Banners are really important part of websites. While flash banners look impressive, flash is no longer supported in some platforms such as you cannot play banners in Android. I would suggest you consider creating your banners with jQuery or even try to use HTML5 for the same.
However, since you asked about a banner designing software, would like to suggest that you try out BannerSnack, I have personally tried this, its really easy and helps you generate high quality banners. An online banner maker app requires no software to be installed, you can design and create your banners online. It supports HTML5 as well and the generated banners are compatible with major ad networks too.
Mclean Buono
