What is the best free android app
Hello ,
This is just a general questions Does anyone know what is the best Android apps you can down load for free.
Hello ,
Hi Johnie,
There are lots of best android applications online. It is free to download. Just go to https://www.google.com/?gws_rd=ssl then type this words ”The best android applications for free”. Google will provide you list of sites that provide free best applications for your android.
Enjoy! I hope this would help you allot.
I will give you a sample site:
Dear User,
They are many applications which are best and good for Android based device. But the good and best depends upon your requirements and purpose.
However here is a few apps considered to be the best by Android users,
1. Check your head (ad supported free version and premium for $4)
2. Astro File Manager (ad supported free version and premium for $4)
3. GTasks(free and handles your tasks wisely)
4. AndroZip File Manager (free, archive based application)
5. Handcent SMS (free)
Here is a website you can download free Android apps from,
http://gallery.mobile9.com/c/android-software/1/
Thank you
