What is the best free hyperterminal alternative to use?
I have reinstalled windows with another CD disc and the old one I used is not available. Now in my computer hyperterminal is not available. So what is the free hyperterminal alternative I can use? Please help me.
Best Answer by Willis K White
Answered By 0 points N/A #157531
Hi!
If you plan to use Telnet or SSH to your other machine and you will be using windows OS, I recommend you install PuTTy. PuTTy is a telnet and ssh client and is used now-a-days than hyperterminal.
I hope I gave you a solution to what you are seeking.
Regards!
Answered By 50 points N/A #157532
Hello Marie,
Check this out. I found these,
“Putty” it is developing originally for the Windows platform.
Putty is free software and also available with source code and is developed and supported by a group of unpaid assistant.
It will be more efficient to you.
And others are,
  • Real term
  • Tera term
  • Absolute telnet
You can download putty here.
Thank you.
Answered By 590495 points N/A #328143
If your computer’s HyperTerminal is no longer working, try these alternatives. First option is the Windows Remote Shell command line. It is available on Windows 7, Windows 8.x, and Windows 10. To explore the different options available on Windows Remote Shell, run the following command in the command prompt:
winrs /?
The Windows Remote Shell or the WINRS command is basically an SSH replacement which allows remote command line access over an encrypted connection. It uses the SOAP protocol. Second option is HTPE or HyperTerminal Private Edition. This one is not free software. This is a commercial terminal emulation program that allows you to communicate with serial COM ports, TCP/IP networks, and dial-up modems.
If you need one good HyperTerminal program, you can try this one out. HyperTerminal Private Edition costs $64.99. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Tera Term is another option. It is an open-source terminal emulator and SSH module that supports the following:
  • IPv6
  • SSH1
  • SSH2
  • Telnet
  • Serial ports
  • File transfer protocols (XMODEM, Kermit, ZMODEM, B-PLUS, and others)
