What is the best freeware soft to convert ai to jpg?
I want to download a software to convert AI to jpg. But I'm not sure which  the best freeware software to convert AI to jpg?
Is it going to be free of cost or not?
Please, tell me in details.
Thanks
Best Answer by Lawren chavez
Answered By 5 points N/A #142764
Hello Brandycarrie,
There are many ways to convert a file having extension AI to jpg.
Any time you want to convert any file. I would suggest you to do it online to keep it safe. Downloading software isn't a safe option. Sometimes the software you are downloading is not trusted, it infects the computer and you might lose your personal data.
Here is a safe way to convert it online:
1. Go to https://image.online-convert.com/convert-to-jpg
2. Choose the file you want to be converted.
3. There are optional settings as well if you want to make further changes, do it.
4. Click on convert file.
You can then save your converted files safely to your computer
Answered By 0 points N/A #142766
AI is an Adobe Illustrator file. It can be converted into JPG format.
There are many types of software for converting pictures. Such as:
1. Format Factory
2. Convert my image
Like these Software's, there are thousands of Software's to convert images. But the best software will be Format Factory.
I use it. With this software, you can convert any picture into JPG.
It also supports video, audio convert.
Answered By 0 points N/A #142765
Hi Brandycarrie,
Do you have Photoshop?
If you say “yes”, you can open you AI file in Photoshop, then “save as” as jpg file.
If you do not have Photoshop, there are some freeware for you to fulfill your need:
  • AI Image Converter 1.1: This software has many useful tools for you to convert and resize your images.
You can download here:
  • ReaConverter: This is useful software too. First, you select your file(s) and add to file list > click Browse button to choose where to save “new” file(s) > In Output format, choose extension (jpg) > click Start button. You can download here: https://www.reaconverter.com/
You can also use some online tool to convert your image:
All you need to do is choose your original file, and then choose the format for the result. Click OK or Convert button
Hope this helps
Answered By 0 points N/A #142763
This is really very easy to convert AI to jpg.,At first you have to download & install the converter from below link
https://www.reaconverter.com/download/reaConverterStandard-Setup.exe .
Now please open ReaConverter & load this AI files in to it- now you have go image edit features. Now come to output extension and save AI files. Now please push Start conversion button and by this way Reaconverter will finish AI to jpg.
