What is the best freeware video capture software?
I am running Windows 7 and I would like to ask what the best freeware video capture software is. It should be compatible with Windows 7.
I would like to make tutorials using my PC and upload it to YouTube. Can you tell me about best video capture software? Where can I download it? Thanks a lot.
Answered By 0 points N/A #136359
Yes, you can find different video capturing software on the web. Many of them are free to download. I will suggest you some video capturing software available on the web. One can download free and you have to invest for other one.
Before purchase the full version, there is a 30 days trial version, which you can check whether it has all the features to fulfill your requirement.
URL1: http://download.cnet.com/Camtasia/3000-13633_4-10665109.html
URL2 (Freeware): http://download.cnet.com/s/free-screen-video-capture/
Hope this may help!
