What is the best ftp webapp?
What is the best FTP web app? Guys can you give me the best websites that tells more about FTP web app? I am making a survey or study about technical and I chose this.
Thank you
Thank you
hi,
You can try the following web address: http\:www.net2ftp.com which is a very good web site. When you visit this site may be you will think from the main page this is not what are you are looking for but once you log in and get into the tool, its actually well designed and very functional.
Aside from the typical uploading and downloading functionality, you can also edit the files online by clicking "Edit" under the actions menu. This is a very useful feature because you can edit web pages on the fly without need to download and then re-upload after edits.
If you are looking for web-based FTP clients that you can access and use with your web browser, try the following:
net2ftp – the first web-based FTP client I found which offers three ways to login to your FTP server: Basic FTP login, Basic SSH login, and Advanced login. The basic FTP and SSH, of course, offers the basic method of logging in to your FTP server which requires the FTP/SSH server, port number, username, and password.
The advanced allows you to select which FTP protocol to use: FTP, FTP over SSH2, or FTP with SSL. It also allows you to set the initial directory and the FTP mode: binary or automatic.
Online FTP – the second web-based FTP client on my list. Just enter the host or the FTP server, username, password, and the FTP port number. According to the site, your login data is deleted as soon as you finish your session.
Dreamhost WebFTP – the third on my list. This service is similar to net2ftp’s advanced login. It also allows you to fill in the start or initial directory and select between “Secure” and “Active” FTP modes.
