What is the best gaming monitor?
I have read that for serious gamers it is of utmost importance to have the proper gaming monitor. I have some gaming monitor criteria suggestions such as a LCD monitor size of 17-20 inches and a response rate below 8 milliseconds. Is there any monitor that fits these criteria?
Best Answer by Micele Asis
Answered By 40 points N/A #158965
Hi Bolton Sander,
I appreciate you for asking that question here. You ask about a desktop that is best suited for gaming. I can recommend you a dell Ultrasharp U30011 30 (LCD Monitor). Its price range is from $1,200-$1,400 and it is instantly good for gaming. It has a 2560×1600 resolution and resolution is not sacrificed because it is large.
Its viewing angles are very excellent because of its IPS technology feature. It is rich and abundant of connections which includes HD MI, displayPort, DVI-D, and USB,. It has also 7 in 1 media card reader for uploading photos on the fly. This is a high quality desktop equivalent to its price. Look at the picture below on how it looks like.
Answered By 0 points N/A #158964
Hello!
I found some companies selling gaming monitors up to the requirements you have mentioned in your question. ASUS ML239H is topmost rated to have the fastest response times .
However, its screen can only be tilted so this gaming monitor might be a little unsuitable for your comfort and it also not very much user-friendly. Its price is about $209.99. The first screenshot shows this gaming monitor.
ASUS VG278H Led monitor has a screen of 27 inches ( I know that you want a gaming monitor with screen 17-20 inches but read along. This gaming monitor is also very good and highly rated as a topmost gaming monitor). It’s response time is 2 millisecond and it can not only be tilted but also adjusted to different heights.
It can also swivel. Its resolution is 1920*1080. You can buy it from buy.com for $700. This might be costly for you but it is also an ideal gaming monitor!  Other two screenshot displays this Gaming monitor.
