What is the best Google cookie decrypter?
Dear Expert,
What is the best Google cookie decrypter that I can use for accessing cookies that my browser saves?
Can I download it as freeware or shareware?
Thank you for the answer.
Pamela Conley
Dear Expert,
Pamela Conley
You can browse through the cookies of the websites you visited in Google chrome. To do so, follow the steps below:
1. Close all applications running, also close Google chrome. Now, press Ctrl+O to open the database of stored items.
2. You will see three tabs in the window, select the data structures tab where you will see a list of all the saved items. See the screenshot below:
3. Now, click on the browse data tab. You will see a list of url's that you visited in the web browser.
4. In the browse data tab, you will see an option called table. In the table tab, select the cookies option. Now, you can see all the cookies that were saved by your web browser.
Hope this information helps you.
If you are looking for some cookie viewer that can help you access cookies a web browser saves on your computer, try the following:
Karen's Cookie Viewer 3.6 – this Power Tool will automatically scan your computer for cookies generated by Windows Internet Explorer, Netscape Navigator, and Mozilla Firefox. The tool can display the data stored in every cookie. Unfortunately, the author of the application has passed away on April 12, 2011 and I’m not sure if they continued it. The author’s website has been down until now.
IECookiesView v1.77 – it is a small utility that displays the details of all cookies created by Windows Internet Explorer on your computer. Aside from that, it has the following features:
