What is the best hard drives for storage?
I am looking for a new hard drive that is nice especially in storing such important files.
I want a hard drive that is worth of its price.
I mean, a hard drive that is in high quality.
Can somebody suggest the best one?
Best Answer by elly23
Answered By 0 points N/A #155219
If you need a new hard disk drive, you can try the Western Digital Scorpio Blue. It brings smart computing solutions that allows high-speed and proficient data transfer. This internal hard disk drive is best for boosting external hard disk drive that is used for gaming and multimedia programs. It also allows you to look and recover your saved data in an instant. The progressive formatting lets you save more data.
The capacity of 500GB, 3Gbps SATA interface with 5400 RPM in speed, an 8MB cache memory lets you store more files. It also has an external data transfer with 300Mbps and Interface SATA II and III. The dimensions are 0.37 inches in height and 2.75 inchec width with a depth of 3.94 inches weighing 0.26 pounds.
The Western Digital Internal HDD inhibits shocks from harming the drive and flat surfaces. It develops consistency and it has a WD Secure Park technology wherein it can give a seamless head placement on a stable position which is far from the disk that guards the disk when not using the Western Digital Scorpio Blue hard disk. This hard disk consist of HQ and been trusted by many people. The price is very cheap and affordable. When you use this hard disk, your computer will run just like a brand new one.
Answered By 10 points N/A #155220
Any brand of hard drive is recommended for office work, but if you have other work that requires more data transfer rate I can recommend Maxtor
Or Western Digital, I do not recommend the use of Samsung hard drives are slow and get damaged very easily.
