Donald Green 200 points N/APosted on - 06/02/2011
There is this video contest that I would like to join. In order to have a high quality video result, I would then need to use the best home video software that I could find. They would use the winning entry on their homepage.
Win 7 is the operating system of my pc. I saw some of the videos submitted of the contestants and I must say that a lot of them did a great job. Aside from the high quality video, their audio is very clear too. Their entries are like made by a professional.
If you are not familiar with other kind of advanced video editors, the basic video editor is Windows Movie Maker which will default comes with your Windows operating system.
Video editing software is also called as NLE (Non Linear Editing). It handles basically the composition of video sequences. Almost all of the Video editing software based on a timeline interface. Then the sections of moving images of the video record, what we called clip, are laid out in a sequence and played back.
These software’s offer number of common tools such like trimming, cutting, splicing. etc and arrange clips across the timeline. And also they are able to color manipulate, visual effects, titling, editing and mixing audio with combining the video.
After completing the NLE project you can then export the movie in variety of formats in for home DVD/VCD, internet, home theater and mobile devices. etc.
There are commercial products as well as free and open source products. You can choose either of them. Here are the popular ones.
Ulead video studio
Pinnacle Studio
Adobe Premiere
Final Cut
Are some of commercial and advanced products which are available for video editing.
Kdenlive
Kino
Cinelerra
PiTiVi
Openshot
Are some of freely distributed open source video editing programs.
This is a process of segments in motion video footage editing, sound recording and special effects. So there are few facts you have to consider when choosing the best suitable video editing software.
If you are working a huge project, I think you know what you need in 1st place. The Memory of course. Let's take one by one. I'll give the facts of my favorite Adobe Premier Pro and my 1st video editing tool Windows movie maker. I never tried out others because I'm satisfied with them for my needs. So you can choose your own regarding to your preferences. If you are a beginner in video editing, from experience I prefer you to choose Windows Movie Maker. Because you will really get confuse when you see the advanced interface of others. Try the basic common tools and identify them from the Windows Movie Maker and then move into other advanced stuff.
AP – Adobe Premier
WMM – Windows Movie Maker
Major point is System requirements
Supported Operating System
AP: Windows, Mac
WMM: Windows
Processor
AP: 1.4 GHz
WMM: 1 GHz
RAM
AP: 1 – 2 GB
WMM: 128 MB
HDD
AP: 4 GB
WMM: 10Mb
Feature set
HD support (High Definition)
AP: Y
WMM: Y
Non-destructive editing
AP: Y
WMM: N
Full screen playback
AP: Y
WMM: Y
Story board mode
AP: Y
WMM: Y
Video Tracks
AP: 99
WMM: 1
Audio Tracks
AP: 99
WMM: 2
Output / Export format
DVD
AP: Y
WMM: Y
HD
AP: Y
WMM: Y
Smart Phone
AP: Y
WMM: Y
Quick Time
AP: Y
WMM: N
WM (Windows Media)
AP: Y
WMM: Y
MPEG4
AP: Y
WMM: N
Web
AP: Y
WMM: Y
After you choosing a video editor, then consider of the output. Which format are you going to use when you rendering the video. Well as this video should be streaming through the web, you have to remember to keep a small size while maintain the quality.
Hope you find out some information for your requirement from the above details.
There’s a lot of video editing software and almost all of them are doing great, but there are also some video editing that’s so hard to use and it can’t give the video and audio quality that you are looking for, but anyway if you are looking for a video editing software then just click the link below, it’s a list of the best video editing software today read carefully about the details of each product so that you can choose the right software for you.
RICH Miner officially launches a new mobile cloud mining application, subverting the traditional mining model! No need to buy mining machines, no technical experience required, just a mobile phone, global users can start the...
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
