What is the best internet cleaner?
What is the best internet cleaner? I am using windows 7 starter operating system. I need an internet cleaner that will clean all the possible and certain area of windows and will probably protect your privacy online. Security is my first priority when it comes to my gadgets especially to my computers.
YOUNG HERNANDEZ
Best Answer by Sierra Adams
Answered By 10 points N/A #165892
Hi Hernandez,
You can clean up your traces and improve your security by removing traces of your internet browsing history. It is dependent on your web browser as well. As you are using windows 7 you might be up to on internet explorer or by Google chrome browser.
1. For Internet Explorer:-
For cleaning your internet traces like browsing history, cookies and passwords, you should use the tip I am about to state. Open browser, then go to Tools. After that click on Delete Browsing History. Select all the fields there and then click delete. All your data, which can compromise your security, will be deleted. The disadvantage is that you can not have Auto Saved passwords, auto completion URL and pre loading of the pages.
2. For Chrome:-
Open the web browser, click on the right most tab a the top, with three stacked bars shaped. Then go to settings. In search panel type, clear. Click on the clear browsing data and select all fields. Then click on clear browsing data.
Answered By 5 points N/A #165893
Hi, you can use this free software for cleaning -up your internet browser, system optimization, registry repair and etc. To start download and using this software, please visit link:
I hope it can help you. Thank you.
Answered By 0 points N/A #165894
Hi Young Hernandez,
If protection from the internet is what you mean just like intruders and viruses then all you need is good antivirus software and strong firewall protection software. You have to download antivirus software and install it to your pc. If you already have one, all you have to do is regularly updating it.
Answered By 0 points N/A #165895
It's very important to regularly clear our browser cache memory by clearing cookies. There are many software to help us achieve that. Anyway, there is another Techyv post which is addressed your problem too. Visit that page and get more idea.
Need a cookie cleaner software
