Jeremy Jack
30 points
Posted on - 10/05/2012
Hello experts,
What is the best jpg view debian? A management tool or software that can possibly extract icons to any other format like jpg and more and can also perform any conversion works. I hope you can give me some tips and advice on how to get a free download for jpg view debian.
Thank you.
Hello Jeremy, My favorite image viewer on debian is XnView. It is very fast, easy-to-use, User-friendly Package that allows to perform simple transformations which you want to do. It has many handy features like EXIF auto-orientation, auto-size images etc.
Go for it.
Hello Jeremy Jack,
Hope that my message finds you well.
You can use XnView tool for jpg view, this tool has many features such as
-Import about 400 graphic file formats.
-Resize, rotate, crop support
-Modify number of colors
-Apply filters (blur, average, emboss …etc.)
-Full screen mode
-Slide show with effects
-Multipage TIFF, Animated GIF, Animated ICO support and much more features, you can go to the site https://www.xnview.com/en/index.php and download it.
Hope this solution will help you and please let me know if you need anything else.
Kind regards,
