What is the best m4a audio converter
I have videos and need to extract audio files from them and convert them to MP3 files. I want to do it in batch too if possible, some files need to be converted into different formats too and might need to add or edit audio effects. What is the best software that can perform the task and how can I get it? Hopefully you can suggest free ones.
