Hello experts,
What is the best management tool advanced? My current operating system is windows 7 64 bit and was wondering if there are some management tool that will probably manage my windows 7 operating system. This is very important for me to keep updated on the status of my computer, thank you.
Windows 7 has built in capabilities to take care of the management features.
Yet, there is a tool called, Windows 7 Manager, which is available at CNET. It is a handy tool for taking care of the management tasks of Windows 7.
The software helps with gathering information about your system, shows information on the running applications, and provides functionality with the applications.
It helps to optimize the system, by taking care of the startup programs, and also helps to protect the computer from known/unknown attacks from malicious malware.
It works as a cleaner, by way of providing advanced uninstaller functions.
It allows customization of the desktop, start menu, task bar and many other amenities of Windows 7.
It provides better security by integrating login information, creating system restore points and by restrictions access to specific locations within the system.
It optimizes network speed and shares network resources in an objective manner.
