Micah Nandy
Posted on - 03/20/2013
In most cases, I forget my urgent works. So, I use some reminder or alarm software. Recently I’ve heard about meeting reminder email sample software. What is the best one in this regard? Please, help the lotus eater.
Thanks
What is the best meeting reminder email sample software?
Hi Micah Nandy,
I would suggest you to use follow up then. Please visit https://www.followupthen.com/
It has many features like schedule reminders directly from your email, recurring reminders, view follow ups in your calendar and so on. It is very easy to use, safe, free and secure.
I am sure this will take care of your forgetfulness.
Hi Micah,
How are you? Hope you are doing well.
The best software to solve your purpose is Lotus Notes from IBM, you will have all your meeting invite in your calendar entries and you can set notification alert in your entries, so that it will give you some reminders about your meeting or any important task. See this image attached, it will give you more insights.
Hope this will help you. Thanks.
Hello Micah,
Here is another email reminder you can try out. It is very smart to have one as there will always be a time when you forget to do something that is urgent.
This will help you stay on track and will assist you in your day to day dealings.
It all boils down to preference and I think this is one of the best email reminders.
Sincerely,
Luz M Terry
