nakon jiko
Posted on - 02/15/2013
I use wifi to connect to the internet in my Samsung galaxy Y. The problem is, I always get disconnected with the wifi connection. I'm planning to buy a Micromax wifi phone with an Android 2.3.5 Gingerbread OS. What is the best Micromax wifi mobile phone?
Hey Nakon,,
Mostly wifi connectivity of the phone also depends on the strength of the connection and also there may be some issues with your current Galaxy Y device. Since all the phones pretty much support the standard Wifi configuration of 802.11 b/g/n. So it pretty much depends on the processor of the phone as to how long it can run it. But If you have already decided on taking a new Micromax phone i would suggest you to take something with a better clock speed than Galaxy Y, preferably Micromax Canvas or Micromax A87 Ninja to the
