What is the best mobile browser?
I'm wondering what the best mobile browser is to use. I have an iPhone 6 and I typically use Google Chrome, but I am wondering what the other options are that would provide me with the best features. I do know that some sites will not load or they will crash on me so maybe if I switch I will get better results. Thanks for your replies.
Answered By 0 points N/A #177515
Safari is a very good browser which is preloaded on iPhone 6 and the best thing about it is it comes with lot of preloaded extensions which somehow helps you to share on other apps easier than the other browsers and make your user experience better on iPhone 6.
You already been using Google Chrome the best part of Google chrome is when you use it on laptop and your phone it says synced which makes your web surfing experience better on both the devices.
Opera mini is a very nice browser and has a very good video and page compression rate which is good for surfing when you have low internet speed.
UC browser is another browser which give you flash support but other than that there are not much features you can consider it for but most sites are now flash free version.
There is an Opera Coast browser which has the same compression feature like opera mini and you wouldn't like it if you like to move to different tabs every now and then.
Sleipnir is a very good browser it has a built in ad blocker and if you like customization this browser does give that feature. List of open tabs are shown at the bottom of the screen which does looks different from other browsers.
But i would tell you to use Safari it has very less known crashing issues. You will get use to it eventually if you keep using it.
