The Maxthon Mobile Browser 2.6.7 claims to be the latest and most user friendly browser for Androids. The only problem is that it works only with an android version 1.6 or a later version.
What is the best browser for a version lower than 1.6?
What is the best mobile browser for android phones?
You are asking about the best version of the android and you can find the situation here. There are many versions and you can find the situation that you can find it anywhere you find the situation and you can know that so many version in this market are available for you so surely you should contact any of the android store and will get the new version which should be best from the previous version and you can find that there are so many versions.
Hope you like solution, if you like this solution that is good and if you need further assistance on it you can contact me again.
Thanks
There are browsers that are always compatible for Androids. Here are some possible browser that was tested – it was tested in real world testing. These are some alternative browser for androids Dolphin Browser HD 7.3 this is highly recommended for mobile browsing in its performance, though it’s not that fast. Second is the Dolphin Mini 2.2 this is the slimmer and faster version, third is the Firefox 10 this is fast when it comes to mobile browsing and fox.
Fourth the Opera Mobile this is the most HTML5 ready browser. Fifth is the Opera Mini 7 has speed dials, search engine but lacks flash and HTML5. Sixth is Chrome (beta) this loads pages faster than the other browsers. Lastly is UC browser this is very popular in China has version for iOS, Windows mobile, symbian, java, and in Samsung bada, it is also fast browser. So can’t you see there are a lot of selections that you can find and this are all free. All you have to do is check it out which of these is more compatible with your mobile.
Hello Jonathan,
Thank you posting your question here. Maxthon Browser 2.6.7 claims that it is the latest version of android version and user friendly and I strongly agree with this statement. It is super fast which is 200% faster than Google chrome, exclusive features which it has free cloud services and it is very easy to customize. This also works with android version 1.6 and later versions.
I hope this will help you.
Hello Jonathon,
Thank you for posting your query here. Aside from Maxthon mobile browser. I recommend you to use the following mobile browser:
Opera Mini
Skyfire
Microsoft IE
Bolt
Just choose any of those I have mentioned above. Those browser have receive positive feedbacks from users.
