What is the best mobile data recovery software for Sony Ericsson w200i?
I’ve been using the above mentioned mobile phone for long time. Suddenly one day I saw that some of my important files has been deleted. Though last of all I knew that my 3-years-old son had done it, I did not get back anything.
So, I need your help.
Please, tell me what the best mobile data recovery software is for Sony Ericsson w200i.
Thanks
Best Answer by Peter A May
Answered By 10 points N/A #177383
Hi Emileekeila,
There is no data recovery software only for Sony Ericsson w200i. You cannot recover your file from your mobile phone. Actually you should connect your mobile to PC, then you can get your lost files by using PCs data recovery software. There are many data recovery software for PCs, you can use them for your mobile data recovery. Just download any data recovery software and recover your file.
I am giving you a link where you can get a data recovery software but I suggest you to search on Google for “Data recovery software” because in the future this link may not be working. This software name is “Recuva”.
Download link- http://www.piriform.com/recuva/download
Best of luck
Answered By 50 points N/A #177384
Hello, Emileekeila
Hope you are fine. You want a data recovery tool to recover your lost data.
Mobile phone data recovery is a software that helps recover your lost data. It recovers deleted data from all types of mobile phone. This software can restore your lost
Photos,
Pictures,
Audios,
Files & folders
Videos etc deleted from a mobile phone.
You may purchase this software from this location.
Otherwise you can try this link where you will get some free tools to download.
Download free tools
Hope you will get your answer.
