Hi techyv,
What is the best mouse driver? I downloaded some before but they are not seemed working fine, it goes to different direction even if I am not still using or moving it. I tried to clean the mouse’s surface and the mouse ball but still the same problem occurs. I need some advice.
 Hoping for your help. Thanks.
Hello Thomas,
Best driver for your mouse is the one given by the manufacturer. Find out the name of the manufacturer and the model number of your mouse. Search for the manufacturer’s website using Google or any other search engine and go to the downloads page. Here you will be able to find necessary driver for your mouse model. Hope this will resolve your problem.
If installing the driver do not fix your issue, you can buy a new one.
