What is the best mp3 player that is NOT an apple product?
The best MP3 player that is not an apple product I would say is Aimp. It is the best audio and a music player that supports mp3 files that I have been using for a long time. The player is beautifully designed and it has tons of features I bet will you like it and make it your default player.
When using AIMP you can be able organize your MP3 files in a library, you can also edit tags and enjoy them all in excellent audio quality. The best thing about this music player is that is has the support for other popular formats as well, which include the karaoke files and several playlist formats. When using it, you will enjoy the use of standard playback functions such as an 18-band equalizer, visualization effects and also a separate window that will enable you to view your current playlist.
Richard Gabriel
When it comes to MP3 players, there are a lot more options other than iPod. You just have to list the features you want for your MP3 to have and you can shop for the best match. Some of the MP3 players we’ve come close when compared to iPod are below:
San Disk Sansa Fuze – By San Disk, it a low priced MP3 player that comes with 8 GB of storage. It is smaller than a credit card, long battery life, and can contain 2000 songs.
Microsoft Zune HD – Offered by Microsoft, it comes in 16 GB or 32 GB thus competing directly with iPod. It has long battery life, high-quality touch screen and HD tuner.
Sony X Series Walkman – Comes with different storage space. As being from Sony, the sound quality is on the top of the line. It has colored LCD screen and 45 hour battery life.
