I need a netbook cooler to prevent my netbook in getting so warm. I found this Zalman netbook cooler. Anyone who will recommend it? Its the first time I heard and would like to get your opinion. Will this netbook cooler for longer used?
What is the best netbook cooler anyone can recommend?
Yes it is! It is good and can longer be use.
It has sleek design with a high quality thick aluminum panel which is good for cooling performance.
Diamond Cutting, Sand Blasting, Anodizing Surface Processing.
It has a rubber grip that will prevent the computer from sliding.
It has two fans which result to fast cooling and pressure performance.
It has high capacity vent holes that distribute the flow of air that will cool the notebook.
It cools the noted book then turns your internal fan to operate quietly with low RPM it is fit to quiet environment.
It will reduce the temperature of your notebook.
You can check it out more from http://www.zalman.com/contents/products/view.html?no=458
Hello Yvonne,
You are asking about Zalman which is a netbook cooler. I have read many reviews about this cooler and many positive feedbacks are thrown by the users. The following are its specifications and components:
1. It is a pure aluminum (base)
2. The colors available are silver and black.
3. It has a dual centrifugal fan
4. It has also two USB port that is convenient to use.
5. Fan speed is adjustable.
6. It has a 928 high capacity vent holes that distributes the cold air to the entire notebook.
I hope the information I given will help you.
Hello Yvonne,
I am using this cooler now and it works great. It really helps cool my laptop especially when using it for several hours when I have many reports to be done, playing doing research and et. Its price is very reasonable because you will not regret when by this product. It has a great performance and I highly recommend you to buy this.
John
I really adore the solution given to this inquiry. Related topics about technology really urged me to visit techyv.com more often. Anyway, here's another netbook cooler for your second choice.
The Enermax Aeolus N14 was first debut back at Computer 2009. Finally it has reached the consumer market and we will find out if the wait was worth it. Fitting right in with the rest of the Aeolus lineup, the N14 is one of the ‘sexiest’ coolers on the market.
It is the latest cooler to join the growing netbook cooler battle and it comes fully loaded: it packs a 140 mm fan with four blue LED and is composed of plastic and aluminum.
Zalman netbook cooler is great .Zalman netbook cooler has sleek design with a very good quality and aluminum panel with a fine curvature and it offers great cooling performance.Its The Rubber Grip Strip prevents the notebook from sliding.Here Premium aluminum treated with D.S.A. Surface Processing.It is designed to minimize user fatigue.
Thanks
