What is the best opensource php catalog script available?
Good day everyone. I'm looking for the best opensource php catalog script available. What scrip can you recommend. For you, is this an easy configuration? If you are going to evaluate its performance, what do you think is your answer? I need an honest opinion about opensource php catalog scripting. The more detailed the answer, the better.
Best Answer by Dyer Pearlman
Answered By 0 points N/A #131235
Hello Salie
One of the best and efficient open source PHP tools and scripts available that I know is “WordPress”. Most of free php scripts need PHP and MySql. I recommend PHP Forums script since it has an easy configuration and it
has also a good performance. For more information, you can check the following link: http://gscripts.net/free-php-scripts/Forums.html.
Answered By 0 points N/A #131236
Hi Salie,
I would recommend scripts from http://gscripts.net/   catalogue. The scripts from this catalogue are efficient and very secure to use in your php based system. The following free scripts are available on this website.
  1. Arcade Scripts
  2. Anti Spam Scripts
  3. Browser Game scripts
  4. Login Scripts
  5. Polls Script etc
These scripts are a good way to add up functionalities in your website. For example the QuickCart script can give you a freeware shopping cart to incorporate in your site.
