Hi guys. Can someone suggest the best PC cleaner 2013? I'm looking for an all in one tune-up utility that can do a disk cleanup, fix registries, defragment and remove unnecessary registries. I need the program to be compatible with a Windows XP 64 bit system. Thanks.
What is the best PC cleaner 2013?
Hi Alex A Gonzales,
There is much more software on the internet. You should go to the google and search for “PC cleaner software”. Then you will get many websites where you can download a cleaner software for your PC. I am using “Advance System Care” it is really best for me. I don’t know which one is best for you because many people use “CCleaner”. Now you can download both softwares and try to understand which one best for you. I am attaching here download links for you just try which is best for you. Here you will get free and purchase version software.
Download link-
http://www.piriform.com/ccleaner/download (CCleaner)
http://www.softpedia.com/get/Tweak/System-Tweak/Advanced-WindowsCare.shtml (Advance System Care)
Best wishes for you
CCleaner features various functions, describing itself as cleaning, system optimization and privacy tool. This software includes cookie management tool and intelligently scans what you want to keep, built-in software uninstaller, invalid system registry entries fixing tool, function to erase free space on the hard drive, and temporary or potentially unwanted files cleaner. It is an all-around software tool that can perform different optimization and management tasks, and is very flexible in terms of operating system version compatibility. Therefore, CCleaner is the recommended PC cleaning software. Visit the CCleaner official website if you opt to download.
I think according to your question this techyv page also will be helpful for you too.
Wanted top 10 pc cleaners!
