I am searching for the best PHP Coder for PC so can someone please send me the links on where I can get it? And please include in your answer the method on running this kind of web scripting. And how I can install it. Thank you.
What is the best php coder pc available?
Dreamweaver CS6 is one of the best PHP, CSS, HTML, Javascript editor. This software will help you to lessen your work because it has a tool where you can just click then type the parameters you want one of them is the DIV TAG. By clicking the insert>TAG >DIV a pop-up window will appear on your screen where you will input the id you want and it will automatically add to your work. The most amazing part here is it has a design preview where you can immediately see the output of your work without using any browser. All changes you made will automatically apply to design preview and you can also see both source code and design preview in one screen.
There are a lot more wonderful features of dreamweaver that you will definitely like.
You need to download first the free trial version of this software or buy with serial which is a full version.
If you already download Dreamweaver CS6, follow these steps:
1. Double click the setup. When a pop-up window appeared just press run.
2. Another window will appear and ask you if you will install trial version or with serial. Just choose serial key if you have and trial version if you don't have.
3. The installation process will start. Wait until it's done.
4. After the installation you can now finally use this software.
Note: if you are using the trial version, whenever you will open this software there is pop-up window that will ask you if you want to use trial version or with serial key just press that trial version button. You will notice a big number with the screen which is the number of days remaining in using trial version. This version lasts within 30 days only. Don't try to uninstall and reinstall again when the trial version is done because you can't use it again.
