What is the best php open source loyalty program software?
I want to use php open source loyalty program software. But which is the best one I don't know? Would you please help me in this regard?
Thanks
Thanks
You can use “NuSphere” which is an php open source loyalty program software. It’s come with various functions. It is easy to use. It has self help function which helps you to show the keywords. When you enter a single letter or some it automatically shows the related keywords. From it's help menu you can get help with various tasks. It also has “php debugger which helps you to debug and fixing errors. So I think it is the best.
Hi Aabel,
You can try Loyalty Program, its a open source extension for Magento e-commerce platform.
It is widely used and has a rich set of features as listed below –
I hope this helps and gets you started in the right direction.
Notifications
