What is the best picture file merger that is suited in separation of unique folders
Hey guys, I have a lot of pictures with different folders, other folders have the same picture with the same file name. Anyone can suggest what is the best picture file merger to be use so that all pictures with the same filename can merge into one folder while others can have a separate folder, so there a two output folders.
