What is the best product of wifi for sitecom?
Sitecom sets up most of the wireless networks available today in making much easier way to surf the net.
What is the best product of wifi for sitecom among all the products offered?
The Sitecom's best Wi-Fi product is Wi-Fi Modem Router N300 WLM260. It creates a wireless network and capable of sharing broadband Internet connection. It can also share files and other peripheral devices. It has ADSL2+ modem that can access all Internet Service Providers directly to your ADSL line.
It has state-of-the-art look and design. The color is black with Matt, shiny, textured finishing that gives it a high-end touch. It has Air vents around the devices for maximum air circulation. The package comes with a stand that allows the device to be positioned either standing up, mounted on the wall surface or in the classic desktop position.
It comes with a speed of up to 300 Mbps and has a range which is optimized for 2 floors. It also comes with an individual pre-set WPA2 security password and you can also create a home network by pushing the OPS (One Push Set-up) Button.
Hello Dave,
As you have mentioned there are lot of Wi-Fi products listed on Sitecom. Choosing the best out of them is something little difficult and it may depend on your requirements.
Even though X6 N900 WLR-6100 is what I’m suggesting for you and it is the best.
Specifications
Thank you.
Rubi Sharlene
Sitecom is best known for their quality wireless gadgets that you can surely trust. Personally I love their N300 X4 WLR-4000 Wireless Gigabit Router.
This device is more than a wireless enhancing gadget it can also protect your wireless devices from cybercrime. Connect it with your broadband connection and configure its wireless connectivity to get your wireless devices such as laptops, tablets, mobile smart phones, and even your gaming gadgets hooked.
Do you own a three-storey house and would like to get crisp connection even on third floor?
This router can definitely provide that. It provides up to 300 Mbps wireless speed and up to 1000 Mbps if you connect your device via LAN cable.
And to top it all, you no longer have to worry about getting illegal access because this router provides Cloud Security that protects all devices connected to it from malicious crimes over the internet.
