Hello experts,
What is the best program for crop video? I need to make a music video with my friends and teammates, I would like to ask your opinion on the best video editing software in the world of technology nowadays. There are some scenes that need to be cropped and edited to be much nicer to view. I hope you can give some suggestions and solutions. Thank you.
There are lot of software those offer video editing facilities, but you have to choose the best one for good results. So I will suggest you to use Videopot Video Editor, which is best ever video editing software on the internet.
I am also posting its link from where you can download it for free but I will recommend you to buy its professional edition which will give you more capabilities to edit your videos.
http://www.nchsoftware.com/videopad/index.html
If you only need a basic video editor then i think this will suit you best. It has the basic tools that you need for cropping, converting & exporting. It also supports the mostly used video formats.
Here's the link:Â https://freemake-video-converter.en.softonic.com/
