What is the best program to edit images?
I want to edit some photos of mine but I find Photoshop very hard to use.
Is there any other software which is user friendly and easy to use.
Please help me with this one.
Thanks in advance.
Thanks in advance.
Hi..
I would like to recommend you Picasa of Google. It's a simple program, and it has all kind of modification you can do..
And even you can get some Online tools from it( for free only) its name is piknik whole function can use this function from Picasa itself..
Thank you buddy 🙂
Hi there user:
What I can suggest is the Windows Live Photo Gallery of Windows 7. I find it easy to use as you’ve request. But the tools for editing process aren’t enough if you compare it to Adobe Photoshop.Â
The second I can suggest to you (if you get bored by using Photo Gallery) is the new online editing software, iPiccy. The iPiccy is an innovative on-line photo editor. And it doesn’t require registration for every user who wants to use it. Ipiccy.com
I hope I did help you with my suggestions. Thanks for posting here at techyv.com.
Best regards,
