What is the best program view photo software out there?
Hi Techyv members. I hope everything is fine. I would like to know what is the best program view photo software available in the online market right now? Can you recommend something for me? If so, why do you think this is the best among the rest. Please also state its key features.
Best Answer by Larsen Monks
Answered By 30 points N/A #136970
Hi there Ruthtmagnuson,
One of the best and most complete desktop image viewers is definitely Picasa. It is free, simple, light and quite attractive with plenty of options for both, viewing and quick editing your photos. You can check it at the following link: http://picasa.google.com.
Another, also free and really popular image viewer is ACDSee.It is stable and fast utility that will give you the whole new experience of looking at your photos. You can find it here: https://www.acdsee.com/en/index.
Best regards,
Drake Vivian
Answered By 0 points N/A #136971
Hi Ruthmagnuson,
One of the best photo viewer to use is Adobe Photoshop Elements 10 its easy to use, cheaper than Photoshop CS6 and with useful features.
For other information please click here.
Thank You.
Hope it could help
Answered By 0 points N/A #136972
Hi  Ruth, Well as for me I find JPEGView image viewer and editor the best because its 2-1 you can view your photos at the same time and do photo manipulation if you want to It can view different photo formats and could edit some of them as well such as   JPEG, BMP, PNG, WEBP, GIF and TIFF images its key features are 1. It's small and fast 2. It preserves the sharpness of the photos 3. Its image processing can be applied when viewing the photos. 4. It can also play photo slideshow.
