What is the best programming language for event planner billing systems?
What is the best programming language for event planner billing systems? I need your suggestion regarding this matter. I have to choose on the best programming application fitted for event planner billing system. Also include some video tutorial together with your suggestion.
Waiting for your support, thank you.
Answered By 0 points N/A #185499
 I will recommend you C# .Net or JAVA as:
For C#:
1] If you are targeting clients for event planner billing system on windows platform .NET frame work provide good GUI interface to develop app, create package, and app developed in this platform is easy to deploy on windows.
2] You can develop application much faster and easily. As user interface is much easy to understand.
For JAVA:
1] Open source.
2] It is easily available on each OS.
If you want to know more about event planner application like design, features, etc. here is video link for you:
http://video.informer.com/s1/win/employee-planner/employee_planner.htm
