Hello fellows,
What is the best programming language to use in creating a client login?
I am still in the planning process, I would like to choose between Java, visual basic, C and c++ programming languages.
I need your opinion based on your experiences about programming languages.
Anthony Wendy.
What is the best programming language to use on creating client login?
Hi Anthoney Wendy,
As far as client login is concerned, I prefer using Java language. Yes, you can use C++ which is more comfortable to use in the Visual Studio 2010 package, but considering the performance, try to use Java. Otherwise, if you are good at C++ use it. If you use Java you can run your application on multiple platforms. That's a great advantage of using the Java language.
Good luck.
Hi Anthony Wendy,
JavaScript is the most commonly used "Client Side Programming Language." the "Client Side Programming Language" actually runs on the website visitor’s hold computer.
Client Side Programming Languages are very practical for making a diversity of rapid changes. For instance, you can use JavaScript to display alternative bits of text. A Client Side Programming Language is tremendously speedy and interactive.
If you want to create Clint login, there are many languages for you. Like- html, c+, c++, PHP, visual basic etc.
I think working in html will be easy for someone.
But if you ask me which one is best for work and give high quality, I will suggest you C++.
Wish you Good Luck.
