Hello experts,
What is the best rdf editor tool? My current operating system is windows 7 64 bit and an intel processor dual core computer. I would like to ask some opinion about a secure and reliable software that can possibly edit rdf files. Please do help me regarding this matter.
If you are looking to work at raw leel and in a human readable/editable syntax such as Turtle then try out rdfEditor i think that will serve your purpose well.
But if you are looking to work in more abstract level (class/ individual) then try out TopBraid Composer or Protege owl.
Hope this solution helps you with your work.
Regards
Rishav D
