What is the best runas utility software to use?
I need runas utility software for my windows xp. What is the best one to use. I saw some are free of cost but some are not free. Can I depend on any free one? On which one? I also saw some encrypted. Please, help me take decision in this regard.
Thanks
Answered By 0 points N/A #138912
RunAs is a substitute for Microsoft’s command “Run as”. If you use RunAs software, you can start an application with other credentials and without log off or log on. There are different versions of RunAs application in the market. As you told, there is free software.  Please note that the free ones are just a trial version. In order to get the full version, you should pay certain amount and then download it. You can download a trial version and use it for 30 days and then go for a full version if you really like that software.
Thanks and regards,
Skarbos Jay.
