What is the Best Screenshot Admin Tool to be Used?
I'm searching for the best screenshot admin tool that can be used to monitor computers in LAN connection. Is there any recommendation that you can give?
The best software to monitor computers on LAN is "Network Lookout Administrator". With the help of this tool you can view the live screens of all the computers on the network.
This software contains a "Console" and an "Agent" option. Console is installed on the main computer on which you want to monitor all the computers on a network. And the "agent" is installed on all the other computers which are being monitored. It also has built in functionality of "Process Killer", and the tools for "lock Workstation", "Log off" and Restart options.
Dear Karengsam,
I will suggest to you a very simple but important process. You don’t need any screenshot software. You can do this easily if you are a Windows user. Follow these steps.
Here the screenshot tools. Download it and enjoy!
I hope this will be helpful for you.
