Hi techyv,
What is the best software 3d model viewer xcode? I don’t have any idea on 3d modeling software in the world of technology. Please do suggest user friendly and secure software. I cannot compromise the safety of my computer system and files.
Hoping for your help.
Hi Shannon,
I will suggest you to use Autodesk AutoCAD. This is the recommended 3D modeling software with great rendering graphics and easy to render 3D objects. The icons were users friendly. It contains number and commonly used materials for constructions and architecture in its materials library. It also gives perspective view with precise sensitivity that allows easy access to different views. Also, it became easy to communicate or send your .dwg file because of its mailing features. You can convert your .dwg file to .pdf file with this program. Also, transforming 2D objects into 3D solids were very easy. Buttons and icons were easy to identify. It gives you a short description on how it works. When the work is done, it grants you different page layout which were ready to be printed.
