What is the best software in converting Apple TV format?
I have many files that is ASF and SivX. I want to convert it on Apple Tv format. What is the best software in converting those files?
Hello there, i think you can use as the best software which have a very good conversion speed and output video file size as well as video quality can be customized and edited i think you should try this Apple TV Converter.
Apple TV Converter although it is not for free, but you will be guaranted that you can convert your other files to Apple TV format.This software is a very versatile one, meaning you can convert video clips and dvd movies to apple TV,you can transfer straight dvd to itunes and put dvd/video on your Apple TV so that you can enjoy all your favorite shows,podcast, videos,dvd, music and videos on your TV.
This powerful software supports quickly conversion AVI,divx, MPG,FLV,MKV,VOB,DVD and more other format that can easily be transferred for your Apple Tv, it also support Apple Tv audio conversion, like mp3,aac,wav.In other words this software can quickly create apple TV movie from any other media formats.It can extract audio.And it can works with other apple products like the ipod and iphone.
I assume you are pertaining to ASF and DivX. If it is, you can use the Wondershare Video Converter Platinum to convert your video and audio to several formats. It supports Apple devices such as iPhone, iPad and iPod.
It can also work with Android and Windows phone, to some video game consoles and a lot more. you can download it here.
You can also use the Apple TV Video Converter to put your ASF files on Apple TV. You can even convert other formats such as AVI, MPEG, DivX, MOV, XviD, RMVB, RM, MKV, FLV, SWF and more to Apple TV format. Download it from here.
Notifications
