Hello fellows,
What is the best software to create back ground picture SWF? I am planning to make a website background with a .swf file extension. What is the possible secure software that renders SWF files? This is a sort of animated SWF format for my business website. I really need your advice about this matter. Thank you.
Marie Philips.
What is the best software to create back ground picture swf?
An animation SWF in the background, then a DIV above with links. In your CSS, the DIV "general" must have a z-index lower than the DIV "content". You may download the code that attached below.
Marie,
One of the good application you can use to do this Giotto software. This is a free window program that creates .swf files. You will download this
application on this site.
In this site, you will find a quick start guide and collection of tutorials that will help you in creating animation on your website background. If understand how to use this application, you don't need to write any code.
This application is supported on windows.
Alfaro.
Hi Marie,
The best software to produce and deploy SWF animation remains Adobe Flash. However there are other ones too out there in the industry which caters to it however its secure and reliable class feature touted as the best version in the industry. You may need to work on developing the skills but it helps you create powerful animations for the website including background one that you are looking for.
Hope this helps.
Baker
If you have .jpg files, you can convert them into .swf files. You just need the AILT JPG to SWF Converter.
Just import your photos and click to convert.
You can download it from this link.
Additionally, if you want to create .swf file downloads and install PowerBullet Presenter from the link below:
This is a free tool for creating presentations in Flash format.
