What is the best software to edit m2v?
Hi techyv,
What is the best software to edit m2v? I wish you can recommend licensed and reliable software. Share with me some of your ideas about photo and video editing software. I am not that good in researching that is why I need some assistance from you.
Hoping for your help. Thanks.
Best Answer by Johnstoon Leen
Answered By 0 points N/A #186226
M2v is an old filename extension used for MPEG-1 or MPEG-2 audio and video file formats. So almost of the software working with MPEG-1 or MPEG-2 can deal with m2v file. But I will list some of them :
– Pinnacle Video Studio
– Ulead Video Studio
– Adobe Premier Pro
With these software, you cut/paste/add effect and other effect can be added to the video.
Answered By 0 points N/A #186228
Hi Ericson Eric
Well here is the best software recommendation for you, you can edit you M2V files easily.
The software name is “M2V Editor” and it is free and have licensed too.
Many users prefer this software to convert their videos to other formats and edit their videos.
M2V is the extension of MPEG-2 video format which uses both video and audio steams.
Second thing you need to know about some good software of photo and video editing.
I’ll recommend you software named “MAGIX”.
It is used for photo organization and video editing.
It’s a light weight and easy to use with user friendly interface
I hope you’ll love these software’s and you’ll use them for your purpose. Good Luck!
Johnstoon Leen
