What is the best software for flash animations of rocks rolling?
Hello friends,
What is the best software for flash animations of rocks rolling? I want to make a flash animation banner for my forum website about falling and rolling rocks. Can you recommend secure and licensed software that can possibly perform flash animation? Also include the possible file extensions that the software can render.
Thanks and Regards,
Allison Davy.
Best Answer by Williamson Mellisa
Answered By 0 points N/A #182157
Hi
I suggest you to download Adobe Flash CS5.
Adobe Flash CS5 software is very powerful in creating animation
This will enables you to create animations in professional way
This software has many powerful features like
Code Snippets Panel
Creative Suite Integration
XML –based FLA source files
Wide Content distribution
Flash Builders Integration
Video Improvements
Deco Drawing tools
 Thanks & Regards
Mckinney Ma
Answered By 5 points N/A #182159
Newest version of Adobe Flash is Adobe Flash Professional CS6. This is the best software for creating animations and other multimedia content. You have extensive publishing support with CS6. With this software is very easy to combine multiple symbols and animations in one single optimized sprite sheer for better work. I’m sure that this will fits your requirements for making flash animation banner for website.
