What is the best software to make webshop system app?
Hello fellows,
What is the best software to make web shop system app? I am planning for an online business regarding computer hardware and need some suggestion about the right programming language to be use. Share and discuss it with me.
Rebecca Green.
Best Answer by lee hung
Answered By 0 points N/A #173649
Developing a web store applications needs good planning and analysis. If you really want to create web shop application go for php and combinations of html, css, jquery is the best to design good user interface with drag and drop controls as a library and use parser with help analyzing your needs and design considerations all are open source so combination good for developing a web store app.
Hope these shall helps you.
Thanks
Answered By 75 points N/A #173650
Rebecca,
Setting up your online store can be a major step for your business. An easy way to do this without shelling out a lot of money to buy the software to do this will be to use:
https://www.makeuseof.com/tag/create-webshop-databases-simplecartjs/.
All you need to is Google this site and you are on your way. This software is set up as a donation based system so its basically free. Once you have loaded the software it will walk you through the process of setting your entire store up. It will be that easy, good luck.
