Hi everyone,
What is the best software for writing chords in mac? I want to be a song writer because I am fan of playing guitar. I need some software that will allow me to automatically draft those chords using mac operating system. I hope this will work fine with mac.
What is the best software for writing chords in Mac?
There are many software available to write chords in Mac. Basically, MAC supports a large variety of music writing software. You can visit the URL http://www.macmusic.org to find the best one fits with your demands. I have heard about a few, Apple – Logic pro (https://www.apple.com/logic-pro/) is one of the best chord writing software for Mac.
From your description, I come to know that you want a automatic chords in your mac computer.
You can download it from several sites.
You can download “Simplechord” 4.2.2. You will get it from this link
This is small but effective software. It will work for MacOS X 10.3.
You will get these facilities from this software:
From power chords to jazz many musical possibilities
It works as your composing assistant.
You can travel easily with iPod
It works with MIDI keyboards
Hope your problem will be solved soon.
