What is best ssd cleaner?
please tell me What is best ssd cleaner software available. I want to reset my SSD Device. please tell me tips and guidelines for using SSD Devices.
Thanks
Thanks
Good day Levine,
There are some good general tips on using SSD device you can simply follow. From my experience, if you are using Windows, use Disk Cleanup utility. It will help you to clean junk files on your SSD disk.
To further clean junk files you can use a software called CCleaner. It does a great job then the time comes to clean your SSD.
NEVER defragment your SSD devices. SSD disks don't need defragmentation unlikely HDD's.
There's a very good article about resetting your SSD device HERE.
I hope this piece of information helps you.
