I am searching for a Survey Sliding Plugin for my Safari browser. Can someone send me the link and the method of installing it on my browser. What are the basic features of it and is there any compatibility issues on installing it on my browser?
What is the best survey sliding Plugin available?
Hi Jimmy,
The WordPress survey plugin is the best if you have a blog and you wanted to incorporate surveys in it.
Visitors can take surveys and you can see the result from the admin side.
The data result can be viewed in two ways:
Aggregate – Similar to poll result, you can see the most favored answers immediately.
Individual responses – View result for one person.
This is only a plug in and can be downloaded here. You can view the version and forums regarding the plugin.
However here is a more detailed instruction in installing WordPress survey.
Opinio is also good.It is registered as freeware with features such as multi language support, architectural plug-in and many more.It supports all major databases like Oracle,MySQL, and SQL Server. It is also easy to install and easy to use which make it very suitable in small or even large organization. You can download it in the link below:
