I have plans to migrate to Windows 8 from Windows 7. I tried the Windows 8 before and I didn't like the interface and there are bugs on some applications and programs especially the Start menu. But, I found in a forum that there are third-party application that will revert the Start menu in Windows 8. How can I revert the Start menu in Windows 8?
Thanks in advance.
What is the best third party in Windows 8
If you want to create a new start menu, try a free tool called start menu reviver. This free utility takes an entire different approach. The Metro start screen displays big, rectangularity. By default, the two big ones on the top are My Computer and Internet Explorer. You can change them. The even bigger one is called "Dashboard" that brings you to the Start screen. Below here that are the 16 tiles which you can set to any installed program like desktop, laptop or modern.
