Hello guys,
What is the best tsm multiple servers?
I want to know more about the server name, domain and users specifications when in terms of multiple servers.
The disadvantages and advantages of this process and flow of the migration of data from one server to another, share with me your suggestions and ideas.
Thank you.
Hi Christine Turner,
In gathering information, I refer you to go to different websites/forums in which they tackle about your concern.
I have attached some sample forums below so that you would have your reference.
ODUSERGROUP Forum: Multiple TSM Servers
ADSM Forum: Multiple TSM Servers
Hope that it would be very much helpful.
Thanks and more powers.
Hi Christine Turner
Well it is not possible to for anyone to share specific node data among multiple TSM servers.
There is specific node data for each TSM server.
You can share library (tapes, tapes drives) among TSM servers which is possible.
You can define specific TSM server instance which is in control of library.
This server usually called the Library Manager (LM).
And the other TSM severs called the clients (LC).
They connect to Library manager, when they need the access of tape or tape drives.
I hope you’ll clear after this solution. Good Luck!
Johnstoon Leen.
