Angela King
10 points
Posted on - 09/26/2012
Hello experts, I would like to ask if what is the best tunneling software? Wherein I can make a proxy setting and log in to servers that do not allow an access or any blocked sites. My friend accidentally blocked some websites and we don’t know how to fix this and I think the best tunneling software can resolve this issue. Please do help me.
What is the best tunneling software?
Hey Angela,
Tunneling software's are great for proxy and you can change the settings as well. You can download PD- Proxy. It's by far the best I have used. You can download it from here-
Hi Dear,
Thanks that you have shared your problem with us.
As you said about the tunneling software, it is 100% true that the tunneling software is much useful for the proxy.
The Best proxy software which i have also used and found it more useful than any other is PD-Proxy.
PD-Proxy provides secure and safe browsing.
You can download it from this link.
http://www.afterdawn.com/software/network/vpn/pd_proxy.cfm
Thanks
Hello My Dear,
Dear tunneling software is used to make proxy settings, and to run a proxy behind.
Dear there many proxy software available on the internet that can help you in this regard.
But I will tell you these two software, these software are perfect in this use.
1. I suggest you to use PD Proxy software.
It is very easy to use and having better results. You can download this software from this website.
2. The other one that is very widely using specially in Pakistan is Ultra Surf. It allows a proxy to run blocked websites. You can download it from this link.
http://www.ultrasurf.com
Thanks
