What is the best version of registry cleaner?
Hello Techyv.com!
I'am operating a computer shop since last year, and it seems that each of my units are having problems with harddrive memory. So I was thinking of a registry cleaner, or of some sort that would help me save disk space. My OS is Windows 7, So may I asked what is the best version of registry cleaner and CCleaner nowadays?
Best Answer by John D Armstrong
Answered By 10 points N/A #167652
Hi Wendy C Moorehead,
CCleaner has three variants. First is a free version but has no customer support, the updates have to be downloaded manually. Second is the CCleaner Professional, Automatic updates of the latest version and is recommended for home users, priced at $24.95. Third is CCleaner Business Edition, Automatic updates of the latest version priced at $34.95. Of the three versions the CCleaner Business Edition might be the good one for you since you are operating a computer shop and maybe manages a lot of computers. With regards to the registry cleaner, the CCleaner also comes with a registry cleaner and many users find it useful in cleaning and fixing registry items.
Hope your are enlightened by this.
Thanks
Answered By 40 points N/A #167654
There are several registry cleaners that have been proved to work very well in one way or another. Among them is Piriform ccleaner, jetclean, wise registry cleaner and advanced system care free.
Piriform ccleaner is highly recommended by many since it’s easy to use, prompts you to backup before it makes changes and will work very well for windows 7 and also other versions of windows.
Thank you.
